Activity › Forums › Adobe Photoshop › Alpha Chanel JPG
  • Alpha Chanel JPG
    Posted by Nathan Kendall on February 28, 2018 at 10:13 pm
    I have a design for t shirt.
    I am assuming it should be in CMYK for print. However when I designed it I had the document set to RGB with a cmyk proof.
    the save as panel says all the formats and below that is alpha Chanel. weather I have jpg or bitmap selected I can not select alpha Chanel. How can I save high res image with alpha Chanel?
    Bouke Vahl replied 8 years, 7 months ago 3 Members · 2 Replies
  • Graham Tees
    March 1, 2018 at 6:38 am
    Jpg does not support alpha channels. If you want to save a transparency channel you need to save as a .psd or TIFF or .png.
  • Bouke Vahl
    March 1, 2018 at 9:05 am
    Jpeg DOES support an alpha channel. Just lots of software does not allow for it.
    After Effects can do this. (although not the tool for this job though.)
    Bouke
    http://www.videotoolshed.com
