Activity › Forums › Adobe Photoshop › Alpha ?
Alpha ?
Posted by Brian B on October 7, 2005 at 10:58 pmJust new to Photoshop and was wondering how I can take an EPS file and convert it to a PCT with alpha intact?
Brian B
Editor
Avid|DS
http://www.trueindiefilms.com
http://www.lithia.comRichard Harrington replied 20 years, 11 months ago 2 Members · 5 Replies -
Richard Harrington
October 8, 2005 at 2:28 amWHICH VERSION OF PHOTOSHOP?
Richard M. Harrington, PMP
Author: Photoshop CS for Nonlinear Editors
Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.photoshopforvideo.comedit – produce – direct –
Brian B
October 10, 2005 at 10:50 pmCS2 is the version.
thanks
–brianBrian B
Editor
Avid|DS
http://www.lithia.com -
Richard Harrington
October 11, 2005 at 1:16 amPlace the image over a transparent background with Place Command… then run the create Alpha channels from visible layers action (part of the Video set in the Actions palette – you may need to load it from the pull down menu)
Brian B
October 11, 2005 at 11:24 pm -
Richard Harrington
October 12, 2005 at 12:39 amYou’re welcome… you might want to use the Inverted action since it looks like you are working on Avids.
