  • Posted by Les Stella on November 11, 2008 at 1:34 pm
    In the help section it says using Uncompressed AVIs are not recmmended. However, I can’t seem to find recommended Huffy UV or Lagarith under the avi save as choices. Am I doing something wrong?
    Alan Lorence replied 17 years, 9 months ago 3 Members · 3 Replies
  • Craig Cooper
    November 18, 2008 at 4:35 am
    These codecs have to be downloaded and are free. Once you have downloaded them simple right click on the file and select install. Windows will then install them to the correct location. The next time you want to render you will see them there.
    I hope this helps.
    Craig
    Cheers Craig
    Peace Talks Hamper War in Middle East
  • Les Stella
    November 18, 2008 at 7:40 pm
    Craig,
    Thanks for the help. It is truly appreciated. You seem to be knowledgeable in this area. Where do I go to download those two codecs? Thanks for your time. If it’s easier for you, you can send them straight to me via email.
    Les.stella@gmail.com
  • Alan Lorence
    November 18, 2008 at 7:45 pm
    Search using your favorite webseach site “Lagarith codec”. Also “huffyuv codec”.
    Alan.
    http://www.wondertouch.com
