Activity Forums Adobe Premiere Pro Alot of videos – How to make them fit the DVD? What bitrate?
  • Alot of videos – How to make them fit the DVD? What bitrate?
    Posted by Victor Clausson on June 12, 2014 at 10:15 am
    Hello!
    I want to make a DVD with alot of episodes from my Youtube-channel. I use Premiere Pro for exporting and Adobe Encore CS6 for creating the DVD.
    All the videos together are about 400 minutes long so I guess two DVD-DL 8,5GB would the best choice?
    400 / 2 = 200 min on each DVD.
    I’ve found that out by using this website: https://dvd-hq.info/bitrate_calculator.php
    It gives me the recommended Maximum, Average and Minimum-bitrate I should choose in Premiere to make it fit on the type of DVD size I’ve picked.
    But, what is the correct worlflow exactly?
    What I do now is that I open my PP-project and export the project to a MPEG2 format with the correct bitrate values given from the DVD calculator website and then one episode is done.
    Should I continue doing this until all episodes are complete and then import them to Encore CS6 or what is the proper workflow for ending up with a bunch of episodes that has the correct size in the end for the correct DVD size I choosed?
    Best Regards!
    Victor
    Steve Brame replied 12 years, 3 months ago 3 Members · 5 Replies
  • Steve Brame
    June 12, 2014 at 11:51 am
    That is typically our DVD workflow – encode the video to DVD specs derived from the DVD-HQ Bitrate Calculator, then import them into Encore. I’ve had much better results from this method rather than letting Encore do the encoding.
    Asus P6X58D Premium * Core i7 950 * 24GB RAM * nVidia Quadro 4000 * Windows 7 Premium 64bit * System Drive – WD Caviar Black 500GB * 2nd Drive(Pagefile, Previews) – WD Velociraptor 10K drive 600GB * Media Drive – 2TB RAID0 (4 – WD Caviar Black 500GB drive) * Matrox MX02 Mini * Adobe CC
    “98% of all computer issues can be solved by simply pressing ‘F1’.”
    Steve Brame
    creative illusions Productions
  • Victor Clausson
    June 12, 2014 at 12:56 pm
    Yeah, me too!
    I’m guessing that Average is Target in Premiere?
    But what about the GOP structure? I, P and B-picture is not in the PP-export window. Are M and N Frames something similar?
    And the last thing I do is to tick the box that says: Use Maximum Render Quality because I read that it improves downscaling?
  • Ivan Myles
    June 12, 2014 at 3:06 pm
    Yes, Target bitrate is the same as Average bitrate.
    B-pictures = 0 translates to M=1
    GOP Limit = 15 translates to N=15
  • Victor Clausson
    June 12, 2014 at 3:54 pm
    Alright thanks!
    When I want to preview the result from the exports, any DVD-player software that you recommend?
    Right now I’m using VLC.
  • Steve Brame
    June 12, 2014 at 4:04 pm
    Though I use VLC too, you should also test on a DVD player. I’ve had many that would play on a computer, but wouldn’t on a DVD set top player – especially an older one.
    Steve Brame
