Activity › Forums › Adobe After Effects › Allowed Ram Usage 0.40GB
Posted by Ken Brockmire on January 25, 2012 at 12:49 pmI can’t seem to get After Effects CS5 to register the fact that there’s 16GB of ram to use.
It registers 16GB installed but when you hit “Details” on the Memory & Multiprocessing preference it says “Allowed RAM Usage 0.40GB”
I’m running win 7 64bit.
Ram reserved for other app’s: 4GB
Installed CPUs: 8
CPUs reserved for other app’s: 2
Ram Allocation per background CPU: 1.5GB
Actual CPU’s that will be used: 0
Any ideas?
Cheers
Tristan Dwyer replied 11 years, 7 months ago 4 Members · 7 Replies -
Walter Soyka
January 25, 2012 at 2:32 pmVery unusual. Is anything else running that’s soaking up available RAM? Have you tried rebooting?
Also, you might be interested in the recommended memory settings [link].
Walter Soyka
Creative Cow Forum Host: Live & Stage Events -
Ken Brockmire
January 25, 2012 at 5:06 pmHi Walter
I’ve tried numerous reboots, and have it running with no other app’s open. Thanks for the link, I’ve tried all sorts of different options under the memory and multiprocessing section so still no joy.
Walter Soyka
January 25, 2012 at 6:31 pmIf you hit Ctrl-Shift-Esc, then click the Performance tab, what does Windows say about your memory usage?
Walter Soyka
Ryan Kelly
January 26, 2012 at 4:19 pmI had this problem and finally solved it by switching from ESET virus protection to a different product. ESET got in the way of pretty much all Adobe memory actions… there might be a setting in eset that fixes it but i sure couldn’t find it…
so… try disabling virus protection and see what happens? May need to uninstall virus software completely…
-ryan
Ken Brockmire
January 27, 2012 at 3:30 pmThanks Ryan, I tracked it down in the end to Comodo Firewall. Uninstalling that has done the job and it’s working as expected.
Tristan Dwyer
February 2, 2015 at 2:40 pmAnyone have any idea how to fix this on a mac? I’m running OSX Mavericks (10.9.2) with After Effects CC2014. It takes agest to start up and when I do I essentially cannot do a RAM preview. Everything works perfect in the previous version of AE CC, but for some reason CC 2014 won’t work.
As I’m on a mac I don’t have any third party virus protection, and have no idea how to disable or even see if I have any firewalls. Any help would be a life saver!
