Activity Forums VEGAS Pro All Temp files into one partition
  • All Temp files into one partition
    Posted by Paul Gregory on April 8, 2005 at 4:04 am
    Both Vegas & DVDA can generate lots of different types of temporary files, peak files backups files etc. Is it possible to set things up so that “ALL” of these just go onto a separate partition so that once the project is finished everything can easily be deleted at once? I had thought of setting up as many others sorts of temp files from other programs into the same partition so that they can be deleted at the same time.
    Edward Troxel replied 21 years, 4 months ago 2 Members · 1 Reply
  • Edward Troxel
    April 8, 2005 at 1:30 pm
    You could set MANY of them to a common location but not ALL. For example, peak files are always in the same folder as the source media – that can’t be changed.
    Just go through File – Properties and Options – Preferences and change all file locations appropriately.
    Edward Troxel
    JETDV Scripts
