Activity Forums Apple Final Cut Pro Legacy All of a sudden my PDW-1500 XDCAM HD will not insert
  • All of a sudden my PDW-1500 XDCAM HD will not insert
    Posted by Anders Haavie on July 16, 2009 at 3:00 pm
    Everything worked perfectly, but after messing with some digibeta mastering, my PDW-1500 XDCAMHD recorder will not Insert edit. (HD SDI) FCP will not let me drag my timeline on the insert”area”.. only assemble. Assembling works great, but its very annoying if I need to fix some stuff on the masterdisks. Have I managed to check a pref that stops me inserting ?
    Anders
    Xraid-Xserve-Xsan-Xeverything
    Anders Haavie replied 17 years, 2 months ago 3 Members · 4 Replies
  • Rafael Amador
    July 16, 2009 at 3:58 pm
    Hi Anders,
    I’ve never worked with one of those disk so I don’t know if to INSERT you need the disk stripped as it happens when working with tapes.
    rafael
    http://www.nagavideo.com
  • Anders Haavie
    July 16, 2009 at 4:16 pm
    I forgot to tell that the disks are striped. Finalcut will not let me drag the timeline to Insert area in edit to tape window, which makes me think that this must a fcp thingy.
    Anders
  • Mark Maness
    July 16, 2009 at 6:19 pm
    Have you set your Easy Setup back to it setting before the digibeta mastering?
    Have you checked to see if a menu setting in the deck has been changed?
    _______________________________
    Wayne Carey
    Schazam Productions
    https://web.mac.com/schazamproductions
    schazamproductions@mac.com
  • Anders Haavie
    July 17, 2009 at 11:40 am
    hmm. It must be easy settings. Will try again when I get to work.
    Anders
