Activity Forums Zaxwerks All my materials are gone?
  • All my materials are gone?
    Posted by John Orban on February 1, 2011 at 7:35 pm
    Working on Mac 10.6.6
    Opened up ProAnimator 4.5.1 for Mac today and found nothing in “Object Styles” – all bins are gray, empty – nothing in “Materials” as well.
    I had a copy of the main Proanimator folder on my server, so I renamed the old file folder in “Applications” (I had a problem with PA crashing when trying to save a file, so I didn’t want to lose the PA main file). Downloaded the PA Folder to Applications and started up the app in the new folder. Same thing – no materials – so there must be some file somewhere ELSE on the computer telling the app where all the files are?
    When I look at the file structure of the PA folder (both the old and new are identical), I see the “Material Swatches” folder populated. I would have thought the .idx files might have gotten corrupted, but I don’t think so, otherwise installing the new folder would have fixed that.
    Not sure what to do at this point?
    Thanks for any help.
    John Orban replied 15 years, 7 months ago 2 Members · 3 Replies
  • John Orban
    February 1, 2011 at 7:45 pm
    I’ve got a sinking feeling that PA4.5.1 is NOT compatible w/ 10.6.6???
  • Matt Rhodes
    February 2, 2011 at 2:16 am
    Hi John.
    PA 4.5.1 should be compatible with 10.6.6.
    We keep a non-factory-default version of the swatches in your ~/Documents/Zaxwerks folder.
    We use these swatches when starting ProAnimator. If the folder is empty, we won’t show any swatches.
    I suggest you find the folder named “ProAnimator” inside of “~/Documents/Zaxwerks.”
    This is where we keep the swatches.
    Rename the “ProAnimator” folder to “ProAnimator – backup” and then restart ProAnimator.
    Since the “ProAnimator” folder is missing, we’ll copy the factory default swatches into a new “ProAnimator” folder.
    You should then see the default swatches.
    Note: In ProAnimator v5 (coming soon), we have put in a Reset button that will make this process much easier.
    Let us know if you have any more questions.
    Matt Rhodes
    Zaxwerks, Inc.
  • John Orban
    February 2, 2011 at 3:20 pm
    You da BOMB, Matt!
    Thanks, everything is hunky dunky now!!!
    John
