Activity Forums Adobe After Effects ALL I WANT…..
  • ALL I WANT…..
    Posted by Reggie Spires on January 24, 2008 at 8:28 pm
    I want the simplest cheapest way to monitor my work with AUDIO on my external monitor. No Capture or HD concerns. I tried the cheap DVcam and there is no audio and when I use a somewhat highend asio based audio card it is not synced obviously with the video on the monitor. I was told the Canapus ADVC110 would do it because it has locked audio but I can’t get AE to see it under Audio hardware. What are the cheap options.
    Reggie Spires replied 18 years, 7 months ago 2 Members · 3 Replies
  • Reggie Spires
    January 24, 2008 at 8:31 pm
    Using Windows 64 .. sorry
  • Brendan Coots
    January 26, 2008 at 5:52 am
    Blackmagic Design has several cards that will give you everything you need, including HD monitoring. If you have a broadcast monitor with SDI, you can use their $295 Decklink card. If your monitor only has component or composite inputs, you need to get their $595 Decklink Pro or above, since the breakout cable accommodates more input types.
    These cards are rock-solid, reliable industry standard gear so buy with confidence – I have two Decklink Pros and a Decklink Extreme, all working flawlessly. We even capture voice over with the Extreme model.
    Brendan Coots
    Splitvision Digital
    http://www.splitvisiondigital.com
  • Reggie Spires
    January 26, 2008 at 4:17 pm
    THANKS SOOOOO MUCH
