Activity › Forums › Apple Final Cut Pro Legacy › ALL FxPlugs are missing…
  • ALL FxPlugs are missing…
    Posted by Dennis Leppell on June 9, 2009 at 6:39 pm
    FCP 6.0.5, on intel Leopard 10.5.7
    I’ve trashed prefs, rebooted several times, ran system update and installed everything. Checked the various proapp and application support folders. The plugins seem to be there, but will not appear in my Effects list in FCP. Tried replacing said plugin folders and such with another copy from a different system, file/folder comparisons show they are identicle. I’ve checked the Effects/Effect Availability/All Effects.
    If it’s an fx plug, FCP doesn’t want to play with it anymore. Smoothcam, BadTV, etc.
    Thoughts? or do I need a bigger hammer….(i.e. re-install time)
    Niclas Bahn replied 17 years, 3 months ago 4 Members · 3 Replies
  • Kevin Monahan
    June 9, 2009 at 7:15 pm
    Trash prefs, and if that doesn’t work, reinstall FCS.
    Kevin Monahan
    http://www.fcpworld.com
    Author – Motion Graphics and Effects in Final Cut Pro
  • John Fishback
    June 9, 2009 at 8:58 pm
    Is FxFactory still installed? You could try running Disk Warrior on your system drive before doing a reinstall.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Niclas Bahn
    June 9, 2009 at 11:51 pm
    Your system may be affected by a problem with the Apple Software Update process that knocks out FxPlug plug-in functionality in Final Cut Pro. Some users have been able to fix the issue more quickly by downloading and re-installing just one component:
    https://www.apple.com/downloads/macosx/apple/application_updates/pluginmanager173.html
    It may be worth your time to try reinstalling just the PlugInManager 1.7.3 update and only then, if the FxPlug plug-ins still don’t appear in the host, reinstall the full suite.
    https://www.noiseindustries.com
