Activity Forums Adobe After Effects all dinamically by expressions
  • all dinamically by expressions
    Posted by Serfior on June 7, 2005 at 2:51 am
    i need to solve something that i cant figure it out how…
    i have a beam effect aplied to an adjustment layer to create line who discovers over time, two layers control, by expressions, beam
    Mylenium replied 21 years, 3 months ago 3 Members · 5 Replies
  • Mike Clasby
    June 7, 2005 at 3:08 am
    If you keyframe the movement of the airplane, then pickwhip the beam endpoint to the anchor point of the airplane (this adds an expression) you should be fine. Unless I’m not understanding what you want to do.
    If the airplane is off just a little bit, adjust the airplane’s anchorpoint to be in the center of the airplane, by double clicking the layer then moving the anchor point in the layer window that opens up.
  • Serfior
    June 7, 2005 at 4:18 am
    i think you dont. the only thing that i want to edit it that two null layers. these null layers set beams and “plane” starting and ening point. i already do the beam effect with de pickwhip but i dont know how to animate the plane with expressions with the coordinates of the null layers. i dont want to keyframe the movement of the plane. i want it to be with expressions.
  • Mylenium
    June 7, 2005 at 4:53 am
    Try this:
    beam_start=thisComp.layer(“Beam”).effect(“Beam”)(“Starting Point”);
    beam_end=thisComp.layer(“Beam”).effect(“Beam”)(“Ending Point”);
    beam_length=end=thisComp.layer(“Beam”).effect(“Beam”)(“Length”);
    X=linear(beam_length,0,100,beam_start[0],beam_end[0]);
    Y=linear(beam_length,0,100,beam_start[1],beam_end[1]);
    [X,Y]
    Mylenium
    [Pour Myl
  • Serfior
    June 7, 2005 at 2:04 pm
    it works perfect!
    is there any way to auto rotate that graphics having these to points? like “Rotating a layer along a motion path”…
    thanks again 😉
  • Mylenium
    June 7, 2005 at 6:12 pm
    That’ easy. I suggest you go to
    https://voir.mylenium.de/creation/tutes/ae_tut_world.html
    All you need to know is explained in this tutorial (including an alternative to the Beam effect).
    Mylenium
    [Pour Myl
