Activity › Forums › Adobe After Effects Expressions › All Caps source text expression?
  • All Caps source text expression?
    Posted by Jacques Levet on July 6, 2020 at 5:55 pm
    Hello everyone!
    I m currently animating a string of numbers and I need them set with the all caps button pressed so they match the height of the letters on another layer.
    However when I apply a character offset animator to the number string layer, it reverts to smaller numbers. I’ve tried with the “preserve digits” option but still no luck
    Is there an expression I can apply to my source text to force the numbers to stay in AllCAps?
    Thank you in advance for your suggestions.
    Filip Vandueren replied 6 years, 2 months ago 3 Members · 2 Replies
  • Scott Mcgee
    July 7, 2020 at 7:50 am
    Not quite sure what the problem is, unless your offset has a scale adjustment on it.
    Either you need to px size on your text, or scale. To firstly make sure that isn’t the issue. If you are using different font then you need to look more into your scale to resize.
    So you’d match the height by using sourceRectAtTime(), which there is plenty of documentation around. Something like this would work. (Pinched from Dan Ebberts)
    s1 = thisComp.layer(“Bottom Line”).sourceRectAtTime().width; //the line I’m trying to match
    s2 = thisLayer.sourceRectAtTime().width;
    s = (s1/s2)*100;
    [s,s]
  • Filip Vandueren
    July 7, 2020 at 8:16 am
    What font are you using ?
    I’ve read about the All Caps trick to force After effects to use Proportional Lining alternatives.
    However I can’t find a font on my system that defaults to Oldstyle AND has Proportional lining alternatives built in.
    So I’m having trouble to replicate your problem, makes it hard to find a solution 🙂
