Activity Forums Adobe Premiere Pro All Caps option in Titler?
  • All Caps option in Titler?
    Posted by Alex Udell on November 9, 2011 at 5:54 am
    Hi All…
    Is there an “All Caps Button” in the titler?
    some times I’ll get something I want to copy and paste from a script as a title block, but I’ll want it all caps.
    is this in the titler? I don’t see it.
    thanks,
    Alex Udell
    Editing, Motion Graphics, and Visual FX
    Andrew Bird replied 10 years, 1 month ago 3 Members · 3 Replies
  • Tim Kolb
    November 9, 2011 at 4:13 pm
    If the text was typed with the Shift or Caps Lock key engaged originally, the text should come across that way.
    If the text was typed into a document where the formatting determined the use of caps, that formatting won’t transfer.
    The closest thing you could do would be to select the pasted text once you’ve released it in the titler, check “small caps” in the text attributes, which will change everything into Caps and will make the “lower case” letters smaller to the percentage value specified. If you want all the letters to be full size, specify 100%.
    TimK,
    Director, Consultant
    Kolb Productions,
    Adobe Certified Instructor
  • Alex Udell
    November 9, 2011 at 4:33 pm
    That’s what I was looking for exactly!!! Thanks Tim!
    Alex
  • Andrew Bird
    August 18, 2016 at 10:32 am
    Another workaround to this 🙂
    Format text in Illustrator then paste into Titler (CC 2016). We’ve found this workflow to be actually quicker than working in Premier Titler for subtitling as we can spell check and change case more easily in Ai.
