Activity Forums Apple Final Cut Pro Legacy All associated audio tracks will not drag into timeline?!
  • All associated audio tracks will not drag into timeline?!
    Posted by Phos Phene on June 28, 2007 at 8:57 pm
    Hopefully this is an easy one….
    When I drag a clip into my timeline, only 1/2 of the audio tracks end up in the timeline.
    I have a video clip with 4 audio tracks associated to it(2 were from the tape and the other 2 were from the boom mic, synced using the “merge” command”
    When i drag this clip into my timeline, all 4 tracks drag down with it. When I drop the clip into the timeline, tracks 3 and 4 dissapear.
    there are 2 “source tabs” enabled. This process works fine with other clips in the same timeline.
    What am i doin wrong?
    fcs 5.1.4
    macbookpro 17″ 2.1ghz dualcore
    Phos Phene replied 18 years, 10 months ago 2 Members · 2 Replies
  • Shane Ross
    June 28, 2007 at 9:07 pm
    DO you see 4 audio tabs next to the timeline when the clip is loaded into the Viewer? If so, make sure ALL of them are connected. If two aren’t (separate from the timeline), click on them to connect.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Phos Phene
    June 28, 2007 at 9:21 pm
    Thanks for the quick response. i figured out the prob just as soon as i clicked “post”
    Basically, there were only 2 audio tracks at the in/out points i had set. lol
    the video track had 2 takes in it, but i was only merging the audio from the first take. so, naturally, 1/2 of the clip only had 2 audio tracks.
    Although, I discovered something interesting in the process. FCP 5.1.4 will not allow me to merge another 2 tracks onto a track that was created by merging.
