Activity Forums Adobe After Effects Alignment issue in After Effects
  • Alignment issue in After Effects
    Posted by Kaushik Kumar on November 29, 2017 at 10:33 am
    Hi there,
    I’m using after effects cc 2017.. I’m using it for quite sometime now… I’ve suddenly got this new problem with aligning the text layers… usually when i select multiple layers and use the align tools to align them it always works no problem… but now suddenly for some layers the alignment tool is not working at all… I used the centre align tool, but the layer is going all the way out of the screen… its not happening for all the layers but just some of them.. i dont understand what the issue is in this i’ve checked all the settings and i’ve reset the transformation settings too, but it still remains. please help me with a solution.
    Ive added Screenshots showing the problem.
    1:
    2:
    Thank you 🙂
    Mark Whitney replied 8 years, 9 months ago 2 Members · 1 Reply
  • Mark Whitney
    November 30, 2017 at 2:57 pm
    I’m trying to understand the values shown for the Unaku layer Anchor point vs. where it appears in the screen shot. Have you tried aligning to Selection first, THEN align to Composition?
