Aligning two SEPARATE film scans of the SAME footage?
Greetings,
I have headache brewing on my screen: I need to align two clips that contain the same footage via different film scans. The reason for doing this is to use an older, poorer scan to restore some crushed/clipped shadow and highlight details done by the last person who messed with the newer scan (I do not have access to the source files nor the film footage else this situation wouldn’t exist!). I’m doing this by using the extract effect to leave only the mid range of the higher quality clip.
Since they are scans of the same footage the motion lines up almost perfectly (they both have been stabilized). The tripping point for me is the geometry of the scans; both scans differ slightly in their geometry and the differences aren’t linear, which means I cannot just adjust the corners. I’ve tried to use meshwarp to align various section of the image however it ends up looking too muddled, liquefy is too imprecise, and the warp functions aren’t too helpful as the clips need to be overlapped for the duration, instead of changing from one to the other.
Any advice on how to accomplish this obtuse task?
