Activity Forums Adobe After Effects Aligning shapes within a single shape layer
  • Aligning shapes within a single shape layer
    Posted by Kaushik Ghara on August 11, 2011 at 3:32 pm
    I have a Shape layer with couple of Ellipse, Rectangle and Polystar shapes. Is there a way to align them as we do for aligning layers ?
    Presently, I am using guides and Ctrl-clicking the individual shapes and positioning them using their anchor points. Would like to know if this is the correct way of doing it or is there a better and faster technique.
    Kaushik Ghara replied 15 years, 1 month ago 2 Members · 2 Replies
  • Greg Burrus
    August 11, 2011 at 3:53 pm
    Have you tried just using the align options in the align panel under windows in the top menu? I would think that would be quicker. This script might also help in aligning the anchor point. https://aescripts.com/repositionanchorpoint/
    hope this helps
    Greg
    https://mogra.g2bproductions.com/ – Blog
    https://g2bproductions.com/ – Portfolio
  • Kaushik Ghara
    August 11, 2011 at 5:39 pm
    Thanks for your response Greg.
    The Align panel works only for aligning multiple layers. In my case, there is only one shape layer which contains multiple shapes. I need to align these shapes within one layer.
    As there is only one layer, the Align panel won’t work.
    Thanks for the script. I will go through it.
