Aligning Long Term Time Lapse
I’ve encountered a curious little problem while producing some long term time lapses of renovations that occurred in an office building over a 10 week period. Due to equipment constraints, the best I could do to capture the process was mark several spots in the building that I would go to weekly and capture 60 frames of construction at the time. All camera settings were the same throughout (5D Mark II + Magic Lantern).
I also created some .BMP images of the first week of shots (one from each location) and loaded them into Magic Lantern’s cropmarks so that I could have a rough reference on screen when aligning the remaining week’s shots.
Needless to say things did not go as smoothly as anticipated. The majority were shot at 16mm and the slightest difference in position becomes very apparent in the form of lens distortion between weeks.
That said, I’ve managed to load one photo from each week into Photoshop using the auto-align layers feature, which created some very nice results. What I’m stuck trying to figure out is how to apply this technique to all 600 frames across the 10 week period. Auto aligning full res RAW images is requires a lot of processing power, however since I really only need to align the last shot of Week “X” to the first shot of week “Y” (and apply that tranformation to the other frames in that week,etc.) I feel as though there’s some workaround I’m missing.
Does anyone have any pointers here? Not sure if I’ve done the best job explaining, so let me know if I can provide anything else to help. Thanks in advance.
