Activity Forums Adobe After Effects Expressions aligning box using expressions
  • aligning box using expressions
    Posted by Antony Buonomo on November 8, 2006 at 11:17 am
    Hi
    I have 2 lines moving over a comp. One moves only on the x-axis, the other only on the y. Therefore, at all times, there is an intersection point between the 2 lines. Imagine something like the cross-hairs of a sniper’s rifle. I would like a small box to always align its centre-point (anchor) to the intersection point of the two lines. Any ideas?
    A
    Mylenium replied 19 years, 10 months ago 2 Members · 3 Replies
  • Mylenium
    November 8, 2006 at 12:30 pm
    X=thisComp.layer(“Line Vertical”).position[0];
    Y=thisComp.layer(“Line Horizontal”).position[1];
    [X,Y]
    Apply this simple expression to the position property of your box.
    Mylenium
    [Pour Myl
  • Antony Buonomo
    November 8, 2006 at 1:45 pm
    Many thanks M, I see the principle of it. And thanks for your recent tutorials, they are prompting me to explore C4D.
    Also, often I see a 3D shape ‘appearing’ as though a 3D mask is wiping on it’s separate surfaces, but the whole leading edge of the mask/wipe is glittering/glowing/sparkling. Is this done in AE or a 3D app?
    Cheers
    A
  • Mylenium
    November 8, 2006 at 5:41 pm
    I wouldn’t bother doing this stuff in 3D. Usually you have much more control in compositing by aligning masks and tweaking parameters.
    Mylenium
    [Pour Myl
