Activity › Forums › Adobe After Effects › align tools
align tools
Posted by Dotan Baytman on May 26, 2005 at 8:25 pmHI can someone explain all the buttons in the align tool?
i cant find info on it in the help file or on the web
thanx in advanceSteve Roberts replied 21 years, 3 months ago 2 Members · 3 Replies -
Steve Roberts
May 26, 2005 at 8:46 pmAligning should be self-explanatory.
The distribute buttons indicate that the tops of layers are evenly spaced, centers are evenly spaced, and so on.
Create three solids in a comp and drag them to different locations. Select them all, click an align or distribute button and see what happens. Undo and try another button.
Steve
Dotan Baytman
May 27, 2005 at 1:19 pmHEY steve thats what i did
i have 3 layers but some of the districute buttons dont do much
i cant understand what they do
any tutorial? -
Steve Roberts
May 27, 2005 at 1:30 pmPlace the solids in random, misaligned positions in the comp. Make sure they are unevenly spaced, and different widths and heights. Try making two layers much closer than the other in one (X) direction, then try doing it in the other (Y) direction. Every solid should look different in shape and size.
Try one of the buttons.
Then hit undo to make their positions uneven again. Or just drag them out of position.
Then try it again with another button.There’s no tutorial for this.
Steve
