Activity Forums Maxon Cinema 4D Align to Spline – Speed Control ?
  • Doug Bassett
    February 28, 2006 at 4:28 pm
    Select the keyframes and in the attributes manager set them to custom. Shift + f4 will open the F-curve editor. you can adjust the keys there for speed and tweek the ease in and out with the bezier handels
  • Greg Paterson
    March 1, 2006 at 9:47 am
    Thanks Doug,
    I am now using V8.5 and I cannot find the “Look Ahead” command for when objects are moved along a spline.
    Greg
    http://www.teliocide.com
    http://www.3D_Icthyomania.com
    http://www.croc_swamp_fishing.com
    http://www.tropical_carp.com
  • Doug Bassett
    March 1, 2006 at 10:09 pm
    Make sure the object is pointing in the z direction.
  • Greg Paterson
    March 2, 2006 at 1:33 am
    There is a function that was called “look ahead”.
    With this function the object travelling along a spline points to a position eg several frames ahead and develops a much more fluid movement along curved splines.
    just cant find how to access this command.
    Cheers
    Greg
