Activity Forums Maxon Cinema 4D align to spline problem?
  • align to spline problem?
    Posted by Emmet Reddy on May 14, 2010 at 4:38 pm
    Hi Im sure there is a simple way to do this.
    If i attach an object like a sphere to a circular spline using align to spline how do i get the sphere to travel around the spline again and again because at the moment i can only go from 0 to 100 percent and then it stops i need it to go continually. Think moon orbiting the earth only very quickly.
    I hope im being clear.
    Thanks Emmet
    Emmet Reddy replied 16 years, 3 months ago 3 Members · 4 Replies
  • Randy Johnson
    May 14, 2010 at 6:59 pm
    Motion clip should do it.
    Or for a circle you could make a helix spline with a height of zero.
    /Randy
  • Cactus Dan
    May 15, 2010 at 2:43 pm
    Howdy,
    If you’re not familiar with my plugins, my CD Constraints plugin has a CD Spline Constraint tag which works similar to the align to spline tag, but with several additional features, like the ability to continue around a closed spline by setting the edit number values above 100% or below 0%. It will also allow you to manually drag the constrained object along the spline in the viewport:
    https://www.cactus3d.com/CDSplineConstraint.mov
    Adios,
    Cactus Dan
    Cinema 4D R10 XL Bundle, BodyPaint, Dynamics
    http://www.cactus3d.com
    http://www.cactus3d.com/Plugins.html
  • Emmet Reddy
    May 15, 2010 at 5:46 pm
    cheers setting the spline height did the trick.
    Thanks Emmet
  • Emmet Reddy
    May 16, 2010 at 8:53 am
    Thanks Cactus Dan, may i also say im getting more into the animation side of things, i had a look at some your CD Character tutorials great stuff.
    All the best Emmet
