Activity › Forums › Maxon Cinema 4D › Align to Spline – Camera movement not soft
  • Align to Spline – Camera movement not soft
    Posted by Chris Arnold on June 16, 2008 at 8:58 pm
    I have a camera aligned to a spline with a rail spline beside it. When the spline path goes forward that curves up with a slight bend.
    The problem I have is that the camera is not always smooth Tangentially. On the curve the camera on a certain frame will rotate really quickly into pointing in the direction that the rail spline intends it to.
    The rail spline is the path spline duplicated and moved to the right.
    Does anyone know what could be causing it? I just need a smooth camera move.
    Adam Trachtenberg replied 18 years, 3 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    June 16, 2008 at 9:20 pm
    Sounds like an interpolated points problem. Try changing the interpolation type to subdivided.
