Activity Forums Adobe After Effects Align Text Left Scripting
  • Align Text Left Scripting
    Posted by Matthew Joal on March 18, 2011 at 12:38 am
    I’m new to scripting with After Effects and I’m having troubles doing the simplest thing. I got most of my program to work just fine, however, when I used the built-in text replace function it changes my text from left aligned to center aligned. I need to set my text layer to left align again after the text it changed.
    Can anyone please help me? I know this is very basic, I just can’t find anything in the scripting guide that will help.
    My last resort option is to set the anchor point of the text field but I would rather just set the alignment.
    Here is the replace function:
    replaceTextInLayer(app.project.item(99).layer(8), “Original”, “New”)
    I just want to left align this text layer.
    Thanks in advance for your help!
    Brian Berneker replied 15 years, 3 months ago 2 Members · 1 Reply
  • Brian Berneker
    June 9, 2011 at 1:55 am
    I have the same problem (right align actually):
    I create a text object, set it right aligned and all is well.
    I then duplicate the object so that it has the same font, alignment etc., and use an expression to get the source text from the first text object. Once I do this, the new layer suddenly changes its alignment to “centered” and is uneditable!
    Solution/Workaround PLOX?
