Activity › Forums › Adobe After Effects › Align Paragraph Text to middle of box?
Marcin Wojtas replied 6 years, 5 months ago 16 Members · 27 Replies
Paul Levin
March 28, 2016 at 4:30 amKalle and Enrique,
Y’all just saved me a HUGE hassle, Kalle for the expression, and Enrique for showing me how to bottom justify.
For anyone with money to spend, iexpressions has scripts for bottom and center justification.
I like Kalle’s version better, the price is right. 🙂 -
Evan Dulaney
August 3, 2018 at 11:09 pmI just figured out another solution to this now very old problem. However, my solution only works if the font size remains consistent.
I set the anchor point of my text layer to 0,0. This puts the anchor point at the bottom of the first line, always.
Then, adjust the baseline shift in the character panel so that the anchor point aligns with the top of the first line instead of the bottom.
then, apply an expression to the anchor point property that uses sourceRectAtTime(time,false); to get the size of the layer and adjust the anchor point.
I only needed mine to be centered vertically, so mine was like this:
rect = sourceRectAtTime(time,false);
[transform.anchorPoint[0],rect.height/2];but you could also do
[rect.width/2,rect.height/2]; -
Matthew Mammola
March 11, 2019 at 6:01 pmwow this is an awesome solution that I wish i understood, but im plenty happy just following your brilliant lead thank you
Evan Dulaney
March 11, 2019 at 6:07 pmWell, sourceRectAtTime gets the rectangular pixel dimensions of a layer. you’re putting that info in a variable, and then setting the anchor point to half of that value.
It’s not the best solution, however, because it can be inconsistent from a typography standpoint. If you’re using lower case letters, and the bottom line doesn’t have any hanger characters (y, g, q, p, j, etc), then the vertical height ends up being different than if there are hanger characters. It’s not an issue if you’re using all caps though ☺
It’s the best thing I’ve found so far though. Hopefully in the future there will be an option to keep the anchor point always centered vertically.
Frederic Antoinette
November 7, 2019 at 4:47 amHi, I think I figured a way, by using a text box, not sure if it will work if not using a text box.
Through test I realise that the sourceRectAtTime().top was always fix whatever font, font size or lines there was in my text box.
Using that info I came out with this code:pY = transform.position[1];
pX = transform.position[0];
R = thisLayer.sourceRectAtTime(time);
c = pY + R.top + (R.height/2);
y = 296 - c + pY;
[pX,y]the 296 value is the Y value i needed my textbox to be vertically centered, since it was a text box and I horizontally aligned and the text itself was horizontally centered I didn’t need to calculate the x value. But I’m sure using the sourceRectAtTime().left and width property, same can be achieve to horizontally center.
Probably lots of room for improvement, but I hope that this can at least help.
Tomas Bumbulevičius
November 7, 2019 at 12:01 pmHey Frederic, just curious – maybe it would give more easier results by applied two expressions below? The reason for this – any place, where you include random, single-use-case numbers, is a bit tedious to work with in the long run.
For position:
W = thisComp.width;
H = thisComp.height;
[W/2, H/2]
For anchor:
sourceSize = thisLayer.sourceRectAtTime(time, false);
T = sourceSize.top;
L = sourceSize.left;
W = sourceSize.width;
H = sourceSize.height;
([L+ W/2,T+H/2])Find out more:
After Effects Tutorials: motion design, expressions, scripting.
Boxer – Dynamic Text Boxes Template with a Live Preview
