Activity Forums Adobe After Effects align footage to actual time mark
  • align footage to actual time mark
    Posted by Juergen Jerzembeck on August 28, 2007 at 9:32 pm
    Dropping footage into the timeline places always at start point 0. Is there a trick to align the footage to the actual time marker curson position? I searched and found an answer from Andrew Kramer, saying “[” would adjust it to actual time mark. Does not work on my version (AE CS3, localised german version).
    Any hint?
    Thank you,
    Giorgio
    Richard Harrington replied 19 years ago 4 Members · 4 Replies
  • Michael Duff
    August 28, 2007 at 10:49 pm
    “[” should do it…. make sure you have the timeline marker where you want it and that the timeline window is selected.
    actually, i just found this thread:
    https://forums.creativecow.net/thread/2/912085
    this may be of more help….
  • Todd Kopriva
    August 28, 2007 at 11:38 pm
    If you drop the footage item into the left portion of the Timeline panel, the new layer will either start at the composition start time or at the current time, depending on whether the Create New Layers At Composition Start Time preference is selected (in the General category of preferences).
    If you drop the footage item into the right portion of the Timeline panel (the time graph itself), then the new layer starts at the time determined by the pointer position when you release the mouse button; you’ll see a time needle in the time ruler that shows where the In point will be.
    This is all in the “Create layers from footage items” section of After Effects Help.
  • Juergen Jerzembeck
    August 29, 2007 at 7:50 am
    Thank you, Todd.
    Changing the preferences and dragging into the preview-window rather than directly into the timeline has solved the problem.
    best wishes
    Giorgio
  • Richard Harrington
    August 29, 2007 at 11:39 am
    [ Moves In Point to Current Time Indicator (CTI)
    ] Moves Out Point to CTI
    Option + [ (or alt) TRIMS layer In Point to CTI
    Option + ] (or alt) TRIMS layer Out Point to CTI
    Richard M. Harrington, PMP
    Author: Photoshop for Video, Understanding Adobe Photoshop, and ATS:iWork
