Activity Forums Adobe After Effects Align circles
  • Align circles
    Posted by Dotan Stern on January 31, 2009 at 9:43 am
    Hi is there a quick way to align a raw of circles?
    i mean i have one circle on top left and one on top right i want to create more circles in between
    i tried the align tool but it didnt made any more circles is there a way to quicly do that?
    also is there a way to that on masks or just layers?
    thanx
    Mark Crenshaw replied 17 years, 7 months ago 3 Members · 2 Replies
  • David Bogie
    January 31, 2009 at 1:56 pm
    [Dotan Stern] “i tried the align tool but it didnt made any more circles is there a way to quicly do that?
    also is there a way to that on masks or just layers?”
    Align will not create new layers or copies of existing layers.
    Open the online help to Shape Layers, might be faster for you.
    Radio Waves can be used to create lots of circles (actually polygons with lots of sides).
    bogiesan
  • Mark Crenshaw
    January 31, 2009 at 3:17 pm
    This can be done easily with Effect>Generate>Circle. You can have multiple circles on a single solid or, copy the effect to other solids and offset the center point of each new circle. I’m just getting started with them but you can also do this with expressions…though how you execute here depends on what you plan to do with the circles during the animation.
    Multiple circles on a single solid:
    1. Create a solid.
    2. Add Effect>Generate>Circle
    3. Set the radius and position of the first circle. Leave it’s blending mode as “None”
    4. Duplicate the effect, set blending mode to “normal”.
    5. Set the position of the circle numerically to align it with the first.
    6. Repeat steps 4 and 5 for each new circle you want.
    Single circle on multiple solids.
    As above but but for step 4, copy and paste the effect onto a new solid. Then do step 5.
    With expressions:
    1. Create a solid.
    4. Add expression to position property. value+[125*(index-1),0]
    5. Duplicate the layer however many times for the number of circles you want.
    The expression will move each new layer 125 pixels on the X axis multiplied by the layer number. This value can be edited to suit your needs. The expression also assumes that your first circle is layer 1, or index 1, in the comp…this number should be the layer number of your first circle.
    Good luck,
    Mark
