Activity Forums Adobe Premiere Pro Aliewnare 14 for video editing
  • Aliewnare 14 for video editing
    Posted by Chris Cavaliere on July 19, 2013 at 1:02 am
    I am doing some humanitarian work in foreign countries and in a couple of months I will need to do some video editing while in the field using Premiere Pro and After Affects. My limiting factor is cash (budget is around $1,200).
    I am looking at getting an Alienware 14 with the following specs:
    – 8GB Dual Channel DDR3L at 1600MHz
    – NVIDIA® GeForce® GT 750M with 1GB GDDR5
    – 4th Generation Intel® Core™ i7-4700MQ processor (6MB Cache, up to 3.4GHz)
    – 14″ WLED FHD (1920 x 1080) Anti-Glare Display
    Will this sufficiently handle Premiere Pro and After Affects? If not, what would you recommend for my budget?
    Chris Cavaliere replied 13 years, 1 month ago 3 Members · 3 Replies
  • Ivan Myles
    July 19, 2013 at 3:12 am
    Under the hood should be OK. Memory might be a constraint if you do intensive AE compositions. My biggest concerns are the 14″ screen size and HDD. First available money should go to a monitor and SSD. Another option would be the Precision notebook; similar hardware to Alienware but with Quadra graphics and matte screen. Look for outlet discounts if budget is tight.
  • Paul Neumann
    July 19, 2013 at 5:02 am
  • Chris Cavaliere
    July 20, 2013 at 11:33 pm
    Thank you for your help. I ended up purchasing a nice machine from the Dell Discount site.
