Activity Forums Adobe After Effects aliasing problem
  • aliasing problem
    Posted by Ron Dejoseph on March 14, 2007 at 7:09 pm
    i made an entire web page in illustrator to animate in AE.
    it’s very clean, and clear, but when i put motion to it, i’m having a aliasing problem with some of the features of the page…lines ‘wiggling’ , etc…
    can i do anything about this?
    thanks as always
    Kevin Camp replied 19 years, 6 months ago 2 Members · 1 Reply
  • Kevin Camp
    March 14, 2007 at 8:05 pm
    this could be a lot of things…
    is the contiuous rasterization option on? its a check box in the switches pane of the timeline taht looks like a little sun.
    are your seeing this on a broadcast monitor or on your computer screen? if it’s on a broadcast monitor it may be an interlacing issue. is it more of a jitter issue on horizontal or near horizontal edges or details? then it probably is a field issue, try a little fast blur, vertical only and repeat edge pixels. if it’s moving, turning motion blur on too may help.
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
