Activity Forums Adobe After Effects Aliasing on animation for NTSC
  • Aliasing on animation for NTSC
    Posted by Avital Pelakh on December 29, 2010 at 2:33 am
    I made a simple animation in AE which I’ve exported to use in Final Cut sequence that is set to NTSC DV 16:9. The animation looks nice and smooth in AE and then looks terrible as soon as it hits FCP.
    Any advice as to what I should do?
    Avital Pelakh replied 15 years, 9 months ago 3 Members · 5 Replies
  • Amit Zinman
    December 29, 2010 at 5:36 am
    What type of animation?
    Does it look good playing with Quicktime or VLC?
    Can you be a little more specific as to the type of “horribleness”?
  • Tudor “ted” jelescu
    December 29, 2010 at 2:31 pm
    Yeah, it would help us to know if you are working in FCP with interlaced or progressive footage. Most times a clip will play jittery if it is a interlaced clip with the wrong field dominance.
    Tudor “Ted” Jelescu
    Senior Compositor/VFX Artist
  • Avital Pelakh
    December 29, 2010 at 2:50 pm
    Thank you for responding.
    The animation is just a guy walking. I created the pieces in Illustrator and used the puppet tool in AE. I exported it using the animation compressor with an NTSC pixel aspect ratio.
    when i play the clip from the finder, there is no aliasing. but as soon as i drop it into my FCP timeline, the aliasing looks really bad.
    my FCP sequence settings are as such:
    Frame Size: 720×480 NTSC DV (3:2)
    Pixel Aspect Ratio: NTSC – CCIR 601/DV (720×480) Anamorphic
    Field Dominance: Lower (even)
    Compressor DV/DVCPRO – NTSC
    Thanks again for responding, I hope I’ve provided more useful information here
  • Avital Pelakh
    December 29, 2010 at 10:59 pm
    Thanks, I changed the settings to Apple Pro Res 422 with square pixels and it seems to be much better, although I had to resize most of the clips on the timeline.
    I appreciate the help!
  • Avital Pelakh
    December 29, 2010 at 11:45 pm
    Alright, now I have a new problem. My animation has a chroma key filter on it in FCP to make it seem like my guy is walking through a bunch of different real world scenes.
    I exported the video using compressor with the Apple ProRes 422 (HQ) setting. Now my aliasing is gone, but my chroma key filter isn’t working in the final output (so i see my animation with green behind it, but no backgrounds). This is not the case when I look at the preview window in compressor.
    any ideas?
