Activity Forums ARRI Alexa onboard audio or double system
  • Alexa onboard audio or double system
    Posted by Jeffrey Weiser on November 29, 2010 at 8:01 pm
    Can anyone who has actually shot with Alexa give me an idea if the onboard audio is sufficient? I am working on a stage doing a commercial with a traditional agency client who is used to instant playback with no issues. Do I need to have my audio guy use a double system? He’s saying everyone is using a double system.
    Jeff Weiser
    Director/Cinematographer
    Directors Syndicate
    jeffweiser@earthlink.net
    John Sharaf replied 15 years, 9 months ago 4 Members · 3 Replies
  • David Battistella
    November 29, 2010 at 8:18 pm
    Yes.
    Double system.
    David
    Peace
  • Gary Adcock
    November 30, 2010 at 9:05 pm
    [jeff weiser] “Can anyone who has actually shot with Alexa give me an idea if the onboard audio is sufficient?”
    No Internal Audio Recording in camera is not due until the next software build-
    But when it is the audio recording internally will be 24bit 48Khz and that is certainly better than the vast majority of internal camera recordings which are usually 32bit and 44.1Khz
    so for the long term the internally recorded audio will be excellent to use in Post.
    gary adcock
    Studio37
    Post and Production Workflow Consultant
    Production and Post Stereographer
    Chicago, IL
    https://blogs.creativecow.net/24640
  • John Sharaf
    December 19, 2010 at 6:13 pm
    Because the audio on the Alexa has yet to be implemented, for now you have to basically treat it as a film camera and “shoot” double system. Where a client wants playback, or instant dailies, I offer to record the monitor output (which is set to Rec 709 with the TC embedded) and the audio from the recordist into a seperate outboard recorder (like a Nanoflash, Ki Pro or even XDCAM deck). This way you can record C-Log to the cards and still have immediate playback/dailies of the 709 pictute with audio and matching time code.
    The one inconvenience is that there is only one monitor output so you’ll have to loop back to an on-board monitor if you’re using one, and you should remember to tiurn of the framelines and on screen monitor displays.
    John Sharaf
    Alexa Owner/Operator
    Pacific Palisades, Ca.
