Activity › Forums › Apple Final Cut Pro › Alexa Log C and FCP X
  • Alexa Log C and FCP X
    Posted by Michael Sanders on July 18, 2013 at 8:47 pm
    I’ve been shooting on an Alexa today and decided to go Log C. Editor is happy at the prospect of using X to edit this.
    I took the footage into X on location and it looks fab, I wanted to show the director of shooting in Log C and thus unticked the Log C box in the info.
    But I didn’t appear to be able to make any colour correction when the clip was in the timeline..
    Was I being silly or is this a “feature”?
    Michael
    V tired in London
    Michael Sanders
    London Based DP/Editor
    Jeremy Garchow replied 13 years, 2 months ago 5 Members · 7 Replies
  • 7 Replies
  • Jeremy Garchow
    July 18, 2013 at 9:45 pm
    [Michael Sanders] “But I didn’t appear to be able to make any colour correction when the clip was in the timeline..”
    Meaning the Color Board doesn’t work or you are missing the “Log Precessing” box?
    You should open the metadata view menu and create a custom preset that includes the “Log Processing” box and select it.
    Jeremy
  • Oliver Peters
    July 19, 2013 at 2:22 am
    It should work. The color board works with or without log processing enabled on the Alexa footage I have.
    – Oliver
    Orlando, FL
    http://www.oliverpeters.com
  • T. Payton
    July 19, 2013 at 4:08 am
    Works on my end too on the Alexa footage samples I have.
    Here is my guess at what might have happened. Your playhead was on clip A and thus showing in the viewer, but you had clip B selected. Therefore you were making changes to clip B, while viewing clip A.
    Just a while guess. 😉
    T. Payton
    OneCreative, Albuquerque
  • Patrice Freymond
    July 19, 2013 at 1:27 pm
    If memory serves me right, the feature only works with Alexa cameras using the latest software version from Arri. Could be the issue you have. (I remember testing it with a 2 year old file and it did not work).
    hope this helps
    Patrice Freymond
    Editor  Certified Trainer FCP7/X
    Post Consultant
    Always learning…
  • T. Payton
    July 19, 2013 at 2:53 pm
    Yes only some Alexa clips that were captured with the proper settings will work, however, I think the OP issue was that the color corrections didn’t do anything to the clip. Not that the log C viewing didn’t work.
    T. Payton
  • Michael Sanders
    July 20, 2013 at 8:41 pm
    Thanks all.
    Turns out I just being silly and tired.
    All working fine now!
    Michael Sanders
  • Jeremy Garchow
    July 20, 2013 at 8:47 pm
    In use the quit and go home method to fix problems as well.
    Most of the time, it works very well.
