Activity Forums Adobe After Effects Expressions Alert Boxes in AE Expressions
  • Alert Boxes in AE Expressions
    Posted by David Markey on July 13, 2015 at 2:28 pm
    are alert boxes supported in AE Expressions?
    I’ve tried some of these in one of my expressions https://www.w3schools.com/js/js_popup.asp
    to give the user an error message if 2 text layers don’t match, but AE tells me ‘property or method window is missing or does not exist.’
    I gather that a script would support this, but I don’t want to require the user to run a script to know that their comp is messed up. My idea for a workaround is to use a text layer with the error message and control the opacity with the expression.
    Thoughts?
    Dan Ebberts replied 11 years, 2 months ago 2 Members · 1 Reply
  • Dan Ebberts
    July 13, 2015 at 3:47 pm
    I think the text layer with the opacity expression is probably the best you can do. I’d make it a guide layer (so there’s no chance of it rendering), locked, and shy.
    Dan
