Activity › Forums › Panasonic Cameras › AJEC3 vs. AJRC10
AJEC3 vs. AJRC10
Posted by Andrew J. cifelli on January 25, 2007 at 3:59 pmI found the AJRC10 to be a bit bulky for the field.
How about the AJEC3 instead?June Verelst replied 15 years, 7 months ago 4 Members · 3 Replies -
Peter Steinman
January 26, 2007 at 2:37 amWell really the AJ-EC3 is only about 1/3rd smaller, half the weight, and has half the blinking lights. It isn’t that much less bulky and does half as much. You’re losing a lot to save maybe 2″ for width. Its the same height and depth.
Jeff Merritt
January 26, 2007 at 5:16 pmHi,
Please remember the two remotes are not interchangeble. The RC10G will only work with the AJ-HDX900 and will not connect to any other camera at present. The EC3 will not work with the HDX900 but is intended to work with all other DVCPRO camcorders including the VariCam.
Jeff Merritt
Product Line Business Manager
High Definition Products
Panasonic Broadcast
323-436-3676 -
June Verelst
February 17, 2011 at 4:53 pmHi, Can someone explain me if it is possible to get an EC3 to work with the HPX300 series? We have one lying around, but I don’t seem to get it up and running out of the box. Maybe I’m doing something wrong.
The units reacts with lights though, but the camera seems to ignore changes.
