Activity Forums AJA Video Systems AJAioLA to Beta via component question
  • AJAioLA to Beta via component question
    Posted by Matt Hall on April 28, 2005 at 3:39 pm
    I have my ioLA (latest drivers and firmware) hooked up to my UVW-1800 beta via the component output of the iO to the component input of the Beta. When I monitor the Beta the picture has a disctinct purple color. I have a feeling this has something to do with the output of the iO being “Pr/R, Y/G, Pb/B” and the input of the Beta “Y, R-Y, B-Y”. Now my video engineering expertise is pretty weak, can anyone give me an explanation?
    Matt Hall
    Director, Digital Post
    CCG MetaMedia, Inc.
    Matt Hall replied 21 years, 2 months ago 4 Members · 5 Replies
  • Bob Zelin
    April 28, 2005 at 6:01 pm
    your B-Y cable is bad.
    Bob Zelin
  • Matt Hall
    April 28, 2005 at 7:17 pm
    Thanks for the response. I’ve changed cables and have the same problem. I’ve connected the different cables from the iO to a monitor and the picture has been fine, then I connect them back to the beta and it’s purple…
    Matt Hall
    CCG MetaMedia, Inc.
  • Lee Berger
    April 28, 2005 at 9:46 pm
    When you say you connected cables to a monitor I assume it was a monitor with component (R-Y, B-Y, Y) input. If so you may have a bad connection on your UVW1800. You might check it with another deck if you can borrow one (any format with Betacam Component in should do).
  • Nick Price
    April 28, 2005 at 9:54 pm
    Matt,
    you might want to check that “view external video” in FCP is not set to RGB 8-bit, but YUV 8-bit. I get the same reults when that is wrong.
    nick
  • Matt Hall
    April 29, 2005 at 1:53 pm
    That fixed it! Thanks for the help.
    Matt Hall
    CCG MetaMedia, Inc.
