Activity Forums Apple Final Cut Pro Legacy AJA Version 6 Drivers out – with RED support
  • Ben Scott
    August 20, 2008 at 8:56 am
    any experience with this update
    does it need specific quicktime 7.5 or final cut pro 6.04 update to operate, this isnt mentioned in readme with update
    I am running on quad G5, kona LH
    was wondering if the AV timing issues resolved would be to do with genlock?
  • Colin Mcquillan
    August 21, 2008 at 1:55 am
    From the “release notes” PDF
    “Installation Notes—Please Read
    Note: Version 6 is only for Final Cut Studio Version 2. Earlier Final Cut Pro versions should not
    use this software. Please ensure you use the correct software for your system. AJA Driver
    Compatibility as of KONA Version 6 software is as follows:
    FCP 6.0.x – KONA Driver version 6.0 (Leopard and Tiger OS compatible version)
    FCP 6.0.x – KONA Driver versions 5.0 through 5.1 NDD (Leopard and Tiger OS
    compatible versions)
    FCP 6.0.x – KONA Driver version 4.0 (Tiger OS compatible version)”
    The download is universal, which would suggest its good for both PPC and intel.
    Colin McQuillan
    Van. B.C.
