Activity Forums AJA Video Systems AJA to HDMI
  • AJA to HDMI
    Posted by Nick Griffin on September 22, 2007 at 2:34 pm
    First, please excuse my relative ignorance on this, but… What’s the best way to connect a high def monitor with HDMI inputs to our Kona LHe breakout box? Thanx.
    Dave Martin replied 18 years, 8 months ago 4 Members · 5 Replies
  • Walter Biscardi
    September 22, 2007 at 3:46 pm
    Hi5
    https://www.aja.com/html/products_converters_HI5.html
    Walter Biscardi, Jr.
    HD Editorial & Animation for Broadcast and independent productions.
    All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • Nick Griffin
    September 23, 2007 at 10:19 am
    Thanx, Walter!
  • David Roth weiss
    September 23, 2007 at 6:10 pm
    Nick,
    I was researching this a few months back and I do recall that there was an issue regarding 24fps playback using the Hi5. You should check with AJA to see what the deal is, or if its been fixed. I suspect that monitoring a 29.97 output from the Kona card would most likely work, but you should probably look into this before buying.
    David
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    POST-PRODUCTION WITHOUT THE USUAL INSANITY
  • Nick Griffin
    September 24, 2007 at 10:45 pm
    Thanx, David.
    Wow. Advice from TWO of the Cow’s most preeminent leaders.
  • Dave Martin
    December 13, 2007 at 8:09 pm
    I would be interested to know if anyone uses this setup as an edit monitor situation (not color correction)
    Dave
    Martin
    – MacPro – Quad Core – 4 gig Ram
    -MacBook Pro – 2.16GHz Intel Core Duo – 2 gig Ram
    -FCP Studio 5.1.4 – QT 7 – OSX 10 – Firmtek Sata Raid- G-raid dv drive
