Activity Forums Storage & Archiving AJA System Test Lite tool for video performance evaluation
  • AJA System Test Lite tool for video performance evaluation
    Posted by Abbott Clark on January 17, 2018 at 10:07 pm
    Glad I found this forum and need this forum’s expert help.
    I am new to video production and learning it. I am evaluating two storage box and using AJA System Test Lite tool for performance evaluation.
    Can I please get guidance on how to decipher the tool’s report and the performance graph to determine if the storage met the “no frame drop” and “bandwidth” requirement for a specific Resolution and Codec selected in the tool to test?
    Below is an example of the output and can I know how to figure out if the requirement is meet?
    Disk Test
    Resolution: NTSC
    File Size : 4 GB
    Codec : 8bit YUV
    Drive : /Volumes/Test
    Cache : Enabled
    Video file: Movie
    Disk Write Test
    Number of frames = 6137
    Write rate = 132 frames/second
    Write rate = 88 MB/second
    Minimum rate = 18 MB/Sec
    Maximum rate = 93 MB/Sec
    [Removed from here the graph for Disk Write Test]
    Disk Read Test
    Write rate = 147 frames/second
    Write rate = 98 MB/second
    Minimum rate = 10 MB/Sec
    Maximum rate = 6674 MB/Sec
    [Removed from here the graph for Disk Read Test]
    Thanks for any help
    Bob Zelin replied 8 years, 8 months ago 2 Members · 3 Replies
  • Bob Zelin
    January 17, 2018 at 10:37 pm
    you are going about this all wrong.
    You are working with video footage from a camera
    What is the resolution (NTSC, HD, 4K, 6K, 8K)
    what is the frame rate (23.98, 30)
    what is the compression codec (ProRes, XDCam, XAVC, R3D, etc.)
    if your answer is “I don’t know” then you need to ASK THE CAMERA PERSON these questions.
    You cannot go into an edit session, with no knowledge of how the media was shot.
    I love when people say “I am working in 4K” – what does that mean – MP4, R3D, ProRes ? There are millions of variables.
    Your answer will help you set this. If you feel that AJA System Test is too overwhelming, try Blackmagic Disk Speed Test.
    You have not even described your drive array that you are testing – how many drives, what is the interface to the computer ?
    Bob Zelin
    Bob Zelin
    Rescue 1, Inc.
    bobzelin@icloud.com
  • Abbott Clark
    January 18, 2018 at 2:10 am
    Thank you for helping a rookie. Now it make sense on the output results of the AJA System test tool. I will ask for the details from the camera person.
    Blackmagic Disk Speed Test can test only till 2K and hence using AJA System Test. Any other test tool to test till 4K?
    One more thing
    Any way to find out the Minimum fps from the Minimum rate given by the tool?
    It will be 12 * 12Gb SAS drives over 10GigE NAS.
    Thanks for your help.
  • Bob Zelin
    January 18, 2018 at 3:47 pm
    Hi Abbott –
    you say that the WRITE rate is 88 MB/sec, but you have not said what you are getting for the READ speed.
    It sounds like you are testing a 1G connection, not a 10G connection. A 1G connection will max out at about 100 MB/sec read and write. Using the free download AJA Data Calc, Apple ProRes 4444 for Ultra HD 4K at 23.98 frames per second required 148.55 MB/sec, so you can see that your system is not fast enough for this. Even regular ProRes codec for 4K Ultra HD at 23.98 is 66 MB/sec, so you are barely fast enough with that array.
    However you state that your array is 12 12TB drives in a NAS. What brand NAS ? Are you the one setting it up ?
    Do you have a 10G connection on your computer (Mac or PC) to go to the NAS ? Lot’s of variables here.
    Bob Zelin
    Bob Zelin
    Rescue 1, Inc.
    bobzelin@icloud.com
