Activity › Forums › AJA Video Systems › AJA LHi Problems capturing HDMI
  • AJA LHi Problems capturing HDMI
    Posted by Jael Dex on December 9, 2010 at 7:31 pm
    hey guys,
    I’m having a bit of trouble…
    I just bought the AJA LHi Card & the Box … Everything seemed to work fine.. until I wanted to capture via HDMI…
    once I connected the Cam to the Break out box via HDMI I was shocked. The picture was PINK !!! And the colors where not as they should be. I tried everything. Even connected the cam direct to the card even skipping the B-OutBox..
    Nothing changed.. FCP = PINK and even the AJA VTR Xchange = PINK
    Some colors are right but everything wath has to be white is PINK.
    But to be shore that the Problem is just considering the HDMI, I tested the HD SDI Input everything worked just fine..
    but that dos not solve my problem.
    The cam has only HDMI out.
    I want to capture HD Uncompressed
    so if any of you got a tip… pleas help me ….
    p.s. I even hooked my Apple TV via HDMI to the card = PINK 🙁
    greets
    Alen
    Jael Dex replied 15 years, 9 months ago 2 Members · 5 Replies
  • Shane Ross
    December 9, 2010 at 9:35 pm
    Try another HDMI cable?
    Shane
  • Jael Dex
    December 9, 2010 at 10:16 pm
    I tried 3 different cables …
    Nothing helped 🙁
  • Shane Ross
    December 9, 2010 at 10:21 pm
    Potential hardware issue. I’d call AJA.
    Shane
  • Jael Dex
    December 9, 2010 at 10:29 pm
    hmm thats what I thought as well…
    I tried the same thing whit my AJA IO HD and everything worked fine ..
    But I’m still hoping to find a way out. And not to send the card to the shop and wait days until l get the new one ..
  • Jael Dex
    December 9, 2010 at 11:01 pm
    I just talked to AJA..
    They told me it it’s a software Problem which will be fixed with the new Update.
    The new Update should come at the end of december.
    So this means Downgrade or Wait ….
