Activity Forums AJA Video Systems AJA LHe with FCP showing no communication via RS-422
  • AJA LHe with FCP showing no communication via RS-422
    Posted by Kat Sicard on September 9, 2008 at 3:27 pm
    I’m running FCP v 6.0.4 with the Kona LHe, which is running software version 6.0. I’m trying to digitize from my DVCPro HD deck, the HD150. In FCP I’m using the easy set-up for Panasonic DVCPro HD, using Aja Kona LH-720 p 59.94 DVCPro HD. Device Control is set to AJA LH: 59.94 Panasonic VTR.
    When I go to digitize, I see the video and the audio coming through fine via SDI, but FCP says that I have no communication with the deck. I’ve tried two different RS-422 cables, so I don’t think it’s a bad cable, and I’ve connected the deck directly to the card. I know I could crash digitize it, but I really need the timecode to come in as well.
    In the Kona LHe Control Panel, under the Timecode tab, I have it set to RP188 LTC, and it is showing the correct timecode there.
    I also tried the card in both expansion slot #2 and #3, and checked the expansion utility to make sure it is running at full speed.
    Any suggestions as to how to get Final Cut to recognize the deck control via RS-422?
    Austin Lea replied 16 years, 1 month ago 6 Members · 12 Replies
  • 12 Replies
  • Ramona Howard
    September 9, 2008 at 5:14 pm
    Does this deck support RP188? and is there a setting on the deck that turns this on/off
    Cheers,
    Ramona
  • Jeremy Garchow
    September 9, 2008 at 6:51 pm
    Can you control any other deck with your Kona?
  • Kat Sicard
    September 9, 2008 at 7:30 pm
    I wasn’t able to control any deck with the card, which was another concern. But I just swapped it back to slot #2, and now it works just fine. It must not have been seated quite right in the slot. Thanks for the help!
  • Gary Adcock
    September 10, 2008 at 5:53 am
    [Jeremy Garchow] “Can you control any other deck with your Kona?”
    Local vs Remote on the deck?
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Inside look at the IoHD
  • Eron Otcasek
    January 13, 2010 at 6:45 am
    i am having a similar problem Both in FCP and in the AJA VTR Xchange Application I have no deck control thru the RS-422 cable that runs out of my AJA card (In final cut pro it says No communication) in the AJA VTR Xchange Application it says: “make sure you are connected to the serial port.” I am sure all my cables are tight. This is the first time I have used this Aja card(cable) cause I’ve just set up a new FCP station. 2.66GHz Quad-Core Intel and I have installed the G-Tech 4-Port, PCIe x4 RAID Controller into slot 4….Aja LHi card in slot 2
    PS I have no remote option on this DigiDeck
  • Jeremy Garchow
    January 13, 2010 at 2:19 pm
    Eron,
    have you installed the latest lhi drivers and firmware?
    In my nehalem macpro, the kona is in slot 3 and storage in slot 2.
    Jeremy
  • Eron Otcasek
    January 13, 2010 at 3:50 pm
    Yes everything is up to date
  • Jeremy Garchow
    January 13, 2010 at 3:55 pm
    Wait, LHe or LHi?
    Jeremy
  • Eron Otcasek
    January 13, 2010 at 4:09 pm
    Lhi
  • Eron Otcasek
    January 13, 2010 at 4:44 pm
    Problem solved!!! Aja cable can go in upsidown! But the Aja logo should be on top!!!
