Activity Forums AJA Video Systems AJA LHe audio problem
  • AJA LHe audio problem
    Posted by Jeremy Rowell on May 24, 2013 at 10:45 pm
    We are running an OS 10.7.4 system that has an AJA LHe using 9.1 driver. We use After Effects and Media 100. Yesterday, when opening a After Effects file and Media 100 project from a newer system, we had a system error. It reads “The A/V hardware is in use as the system sound” ” You must select a different device in System Preferences/ Sound/ Output”
    Now we can’t switch from After Effects or Media 100 to anything including the finder without causing the error. I’ve tried switching the system sound setting from AJA back to line out, but it automatically switches back. Any ideas? It really sucks having to quit a program every time you get an email or want to look for a file!
    thanks,
    Jeremy
    Jeremy Rowell replied 13 years, 3 months ago 2 Members · 2 Replies
  • Kevin Reiner
    May 28, 2013 at 8:32 pm
    I’m having similar issues, but using Premiere with Aja LHi. If I go preview a file in finder, audio starts to go wacky in Premiere. Really a pain. Hope there is an answer.
    Mac Pro 2 x 3 GHz 6-Core Intel Xeon
    32GB Memory
    Dual-channel 4Gb Fibre Channel PCI Express card
    Dell Display (23″ flat panel)
    ATI Radeon HD 5770
    AJA Kona LSi SD/HD capture card
    Rourke 16 TB
    Flanders 2460
    SOFTWARE
    Mac OS X 10.6.5
    FCP 7
    After Effects CS5
    Boris Continuum
    Sapphire Plug Ins
    All Trapcode Plugs
    Zaxwerks Invig
  • Jeremy Rowell
    May 29, 2013 at 8:03 pm
    I ended up dumping all my preferences for AJA, Media 100, and After effects. Not sure what one was the offender, but it is back to normal. I can have them all open at the same time and switch freely through them.
