Activity Forums Apple Final Cut Pro Legacy AJA LA or DecklinkSP?
  • AJA LA or DecklinkSP?
    Posted by Matt Short on December 3, 2005 at 3:13 pm
    Would I gain any performance using the DecklinkSP over the AJA LA? I have a Dual 1.4 G4 and a 1.25G4 Powerbook. I would like to get the AJA LA so I could capture BetaSP right into the Powerbook on the road. Any suggestions?
    Matt Short replied 20 years, 9 months ago 3 Members · 3 Replies
  • Walter Biscardi
    December 3, 2005 at 3:23 pm
    [matt short] “I would like to get the AJA LA so I could capture BetaSP right into the Powerbook on the road. Any suggestions?”
    I think you answered your own question. If you want flexibility to capture to any Mac, then the Io LA is the way to go. I have one here to use with my two Kona 2 systems and the laptop. Flexibility is the key reason I purchased it as it just connects to whichever machine needs analog inputs.
    Walter Biscardi, Jr.
    “The Rough Cut,” an original short film premiering December 7th in full High Definition in Atlanta.
    rsvp@biscardicreative.com to reserve seats.
    https://www.theroughcutmovie.com
    Now editing “Good Eats” in HD for the Food Network
  • Frank Nolan
    December 3, 2005 at 5:17 pm
    Just be aware that the AJA wont play well with anything else on the firewire bus, so if you want to capture to an external drive on the powerbook you will need to get a PCMCIA firewire 800 card. I have a G-Raid on that card and can capture uncompressed from Beta SP with a 1.5ghz laptop.
  • Matt Short
    December 3, 2005 at 5:52 pm
    Thanks for the responses!
