Activity Forums AJA Video Systems Aja LA & Kona 2 (Can they work together?)
  • Aja LA & Kona 2 (Can they work together?)
    Posted by Lawrence Roussarie on January 25, 2007 at 12:33 am
    Hello: I have a Kona 2 card and want to add the – Aja LA i/o for component video and analog audio.
    Can I select the LA to output/input analog while as the same time outputting/inputing SD video from the Kona 2 card?
    Any issues with this?
    I’ll take a link…
    Larry Roussarie
    Jeremy Garchow replied 19 years, 8 months ago 2 Members · 1 Reply
  • Jeremy Garchow
    January 25, 2007 at 1:17 am
    It’s one or the other, not both for input. You can get yourself a full io, hook it up to the Kona2 via SDI and then use that as a video router of sorts for all kinds of output, input is only one source though, or you can hook the component out to your la and route the signal analog as well.
    Jeremy
