Activity Forums Media 100 Aja Kona output part 2
  • Aja Kona output part 2
    Posted by Jack Shepard on February 25, 2014 at 9:17 pm
    After my Aja he reversed cord issue – I have a definite signal out to the monitor attached to the breakout box but something is happening that I can’t figure out. I’m using component output to a simple HD LCD.
    When my video output settings in M100 are set to SD component – it outputs to the monitor fine in SD
    When my video output setting in M100 are set to HD component – the image outputs in HD but the screen is offset to the left (basically the image has shifted over leaving a big black bar down the right of the screen and cutting off the left side of the video). My timeline is 1080psf 23.98fps and it shifts over to the left if the Analog HD Std is set to: HD 1080i/psf or HD 720p. I get no image if it is set to 1080p.
    The rest of my setup is as follows:
    I am running:
    2 x 3ghz Quad Core Intel Xeon
    Mac OS X (10.7.5)
    Aja Driver 9.1
    M100 Version 2.1.5
    Any ideas why it is outputting strangely?
    Jack Shepard replied 12 years, 6 months ago 2 Members · 2 Replies
  • Gerry Condez
    February 26, 2014 at 5:49 pm
    Here is my setting:
    Output Kona
    SDI 1 HD 1080i/psf or HD 720p
    Analog HD Component
    Check the monitor setting. If the monitor is only up to 720 then it will show
    strange images. Or, try analog to SD Composite
  • Jack Shepard
    February 27, 2014 at 4:05 pm
    Thanks Gerry – I think you may be right. I’m going to try swapping monitors and see what happens.
