Activity Forums Media 100 AJA Kona & MXO2
  • AJA Kona & MXO2
    Posted by Gerry Condez on September 4, 2012 at 4:12 pm
    Will it work if you have both AJA and Matrox cards reside in one macpro? I tried installing both and Matrox disappeared from media 100 just kona. Thanks
    Marshall Houskeeper replied 13 years, 11 months ago 2 Members · 1 Reply
  • Marshall Houskeeper
    September 4, 2012 at 8:17 pm
    You can have both AJA and Matrox cards installed in you computer at the same time. However the way the Media 100 software works it that it uses the first card it finds. The order of search is AJA, BlackMagic and then Matrox. In you case, if your remove the AJA driver the software will find the Matrox card.
