Activity Forums AJA Video Systems AJA Kona LHe Synch problems…
  • AJA Kona LHe Synch problems…
    Posted by Jason Lyons on February 14, 2009 at 8:14 am
    Hi All,
    I just moved a DVCPRO HD 720p60 project from a G5 system with a Kona 2 to a new 3.0/8-core MacPro /16G RAM AJA Kona LHe (w/K-box).
    The FCP playback setting on the new MacPro is set to 720p59.94 8bit just as it was on the old G5 system. I am monitoring video with the Kona card via HD-SDI the audio via kona RCA’s on the breakout. The audio and video stay in synch for about 5-6 seconds then starts drifting. If I just playback using the Digital Cinema Display option I can use my computer monitor and playback with no synch issues. A lot of posts about this issue suggest to make sure the Kona card is placed in PCI slot 3 (which mine is), or to run the expansion port utility, tried and it doesnt run on this machine. I have the latest Kona control panel software… but I cannot seem to find a fix. Any ideas?
    Jeremy Garchow replied 17 years, 6 months ago 2 Members · 3 Replies
  • Jeremy Garchow
    February 14, 2009 at 6:21 pm
    You have a newer MacPro so you don’t need the expansion slot utility.
    For an LHe you need Slot 2
    https://www.aja.com/html/support_kona_rec_sys.htm
    Jeremy
  • Jason Lyons
    February 14, 2009 at 9:15 pm
    Many thanks that did the trick! That’s at least worth 2 beer credits, put it on my tab. I dont know where you found that document on their website, but I certainly didnt see it on the KONA LHe / LH Support page.
    Thanks again.
    j
  • Jeremy Garchow
    February 16, 2009 at 12:21 am
    [Jason Lyons] “That’s at least worth 2 beer credits, put it on my tab. I dont know where you found that document on their website,”
    🙂 Gladly.
    The document is linked to from the “System Recommendations” box on the right side of this page:
    https://www.aja.com/html/support_konaLHe_swd.html
    Jeremy
