Activity Forums AJA Video Systems Aja Kona Lhe and Playback with Machina
  • Aja Kona Lhe and Playback with Machina
    Posted by Jeff Burford on July 12, 2012 at 3:01 pm
    Haven’t use the system in a while for Video, but for some reason, now playing back HD Materials, shows a mild flashing on and off of a few lines of green or black at the bottom of the video frame instead of steady full frame HD. HD Video Output.
    If I playback SD Footage, this problem does not occur.
    Any ideas what could be causing this?
    Before I forget, am using a HP Z600 with 6GB of RAM, and Windows 7 64 Bit Professional. Aja Lhe, with Software version 5.03.
    Jeff Burford replied 14 years, 1 month ago 2 Members · 2 Replies
  • Alex Gerulaitis
    July 12, 2012 at 8:14 pm
    Have you tried updating graphics and AJA drivers, reseating the cables, and shaking the system a bit to whip it back into behaving?
    Alex Gerulaitis
    Systems Integrator
    DV411 – Los Angeles, CA
  • Jeff Burford
    July 13, 2012 at 7:17 am
    Grin, not quite yet. But, guess I will do just that, check and seat cables, cards and such and check the latest graphics driver. For the Aja Driver, I believe that I am stuck at 5.03 since I am using the Lhe with Adobe CS 5.0.
    It is my understanding the the newer Aja Drivers require Adobe CS 5.5 or 6.0.
    more later
