Activity Forums AJA Video Systems AJA Kona hardware solution
  • AJA Kona hardware solution
    Posted by Dennis Noel gomez on February 4, 2014 at 1:06 am
    Hi Guys,
    I’m currently looking into upgrading my old MacPro system with the new MacPro.
    I also use a Blackmagic Decklink Extreme card in my old MacPro.
    I need a new hardware solution since the new MacPro only uses thunderbolt (and HDMI or USB 3) devices.
    I use the Blackmagic Decklink card by:
  • Sending a video/audio signal from the edit suite to the client viewing monitor via analog signal (analog cables are running under the carpet, will need to upgrade to HDMI eventually)
  • Receiving an audio signal from the Audio booth via XLR – the Audio booth is connected to a Sound Mixer which is then connected to the Audio-In of the Blackmagic card.
  • Can anyone suggest a hardware solution that will address my current situation?
    Kind regards,
    Dennis Noel Gomez
    Video Editor
    Motion Graphics Designer
    Take One Productions
    Dennis Noel Gomez
    Video Editor
Aja Sales department replied 12 years, 6 months ago 2 Members · 1 Reply
    • Aja Sales department
      February 5, 2014 at 6:41 pm
      You may want to look at the AJA Io XT:
      https://www.aja.com/en/products/io-xt
      The only item from your list that the Io XT does not natively offer is analog audio input. This could be accomplished via the use of a converter, such as the AJA HD10AMA, used in combination with the Io XT:
      https://www.aja.com/en/products/mini-converters/hd10ama
      Also, be aware that for analog audio output, a user-supplied DB-25 audio cable is needed.
      If you have additional questions, please feel free to contact the AJA Sales Department via phone or email, Monday through Friday, between 9am and 5pm PST.
      AJA Video Systems
      +1 (530) 274-2048 Intl.
      (800) 251-4224 US
      sales@aja.com
