Activity › Forums › Adobe Premiere Pro › AJA Kona 3G with Premiere Pro
  • AJA Kona 3G with Premiere Pro
    Posted by Aaron Barton on April 2, 2012 at 5:56 pm
    Hey everybody,
    So I’m trying out Premiere Pro and I’ve run into a problem and was wondering if there is something that I’m missing. I’m trying to get video playback out of the Kona for both my reference monitor and my client monitor when cutting 1080p23.976. The problem is that my client monitor doesn’t accept 1080p23.976. What we’ve done in the past with FCP was have our sequence be 1080p23.976, but view the playback at 1080i 29.97. I can’t seem to figure out how to do that in Premiere Pro.
    Also, I’ve noticed some performance issues when changing my player in preferences from Adobe to AJA.
    Any help would be appreciated.
    Aaron
    Mac Pro
    Premiere CS 5.5.2
    AJA Mac Plug-ins for Adobe CS5.5 Version 10.1.1
    Kona 3G
    KONA 3G Driver Version 10.1
    Quadro 4000
    Quadro Driver 256.02.25f01
    OS X 10.6.8
    Chris Borjis replied 14 years, 5 months ago 2 Members · 1 Reply
  • Chris Borjis
    April 2, 2012 at 6:07 pm
    Hi Aaron,
    I’ve run into a similar pickle. I can monitor externally from
    my Kona LH-e in 23.98 but I can’t stand the 48hz flicker my
    sony crt makes in 24p mode.
    And like you said, in fcp you could add pulldown for playout
    on monitors that don’t support 23.98.
    here is one thing you can do to add monitoring though
    I don’t know it is the best solution.
    create a 29.97 sequence.
    copy all of your 23.98 sequence and paste it into the 29.97.
    that should work so you can monitor. It plays back fine on my
    setup here. But I don’t know what premiere is doing to the framerate.
    converting it or adding pulldown.
