Activity › Forums › AJA Video Systems › aja kona 3g capture issues
  • Jeff Brown
    February 16, 2011 at 9:00 pm
    What are you capturing from, and to what format???
    -Jeff
  • Lacy Mcdowell
    February 17, 2011 at 3:15 pm
    capturing 1080i 59.94fps 8bit yuv 422 ‘2yuv’AVI format. SDI stream from a dvcpro ajhd1700 deck using adobe premiere cs5. The video preview in adobe capture windows break apart with flickering black horizontal black lines and shifting video. playback on timeline is the same.
  • Jeff Brown
    February 17, 2011 at 11:35 pm
    Are you using a sync generator to lock the systems? You may need to.
    -J
